Access to another hololens's camera video stream from unity
I'm building an app in which I would like to connect to another hololens's camera video stream and display it on a texture.
I've found the following url that can be colled from VLC:
http://
Depending on the machine it shows a certificate. After accepting or installing this as trusted, it ask for the login username/password. After this I can see the stream in VLC.
Now I would like to get this stream in Unity3D. I've tried various methods using WWW, HttpWebRequest, etc., but I keep running into different problems with each approach.
Does someone else know how I can get this to work?
Thanks
Roy
OptionsPatrick mod
It depends on how you want to go about this. The easiest way would be to hard code the IP address of your unity editor, create a network connection, and stream the bitstreams. The pattern for doing it this way is in the spatial mapping scripts in the HoloToolkit. In those scripts we send mesh data, but you could send the texture data instead. The important bit is that you use a different API in the Unity editor than you use for a UWP app like HoloLens.
So in HoloToolkit look at SpatialMapping\Scripts\RemoteMapping.
Thanks, I've got it working
@royarents I am doing a similar thing for one of my school projects. Could you please share some insight, like how did you go about doing it?
What is the thing I should do first? Is there a code sample that does that, on which I can build on. I am suing Unity.
