Access to another hololens's camera video stream from unity
I'm building an app in which I would like to connect to another hololens's camera video stream and display it on a texture.
I've found the following url that can be colled from VLC:
http:///api/holographic/stream/live_high.mp4
Depending on the machine it shows a certificate. After accepting or installing this as trusted, it ask for the login username/password. After this I can see the stream in VLC.
Now I would like to get this stream in Unity3D. I've tried various methods using WWW, HttpWebRequest, etc., but I keep running into different problems with each approach.
Does someone else know how I can get this to work?
Thanks
Roy
    Thanks, I've got it working
    @royarents I am doing a similar thing for one of my school projects. Could you please share some insight, like how did you go about doing it?
    What is the thing I should do first? Is there a code sample that does that, on which I can build on. I am suing Unity.
