Emulator troubleshooting with GalaxyExplorer
Was able to get my issues squared away running the emulator, but now I can't seem to deploy GalaxyExplorer to it. The emulator runs, but I get this output:
DEP6100 : The following unexpected error occurred during bootstrapping stage 'Connecting to the device 'F957827B-6FC8-4538-A5BA-3B3807152A56'.':
MissingMethodException - Method not found: 'Boolean Microsoft.Tools.Connectivity.RemoteDevice.Ping()'. GalaxyExplorer
UX Designer @ Anki
wintermoot ✭✭
Fixed my issue by installing the Remote tools for Update 2:
UX Designer @ Anki
https://www.twitter.com/wintermoot5 -
wintermoot ✭✭
this was ultimately fixed by uninstalling both windows SDK's and installing just 10.0.10586. then, rebuilding the csproj in unity
UX Designer @ Anki
https://go.microsoft.com/fwlink/p/?LinkId=534786
UX Designer @ Anki
I have a similar issue, but the Remote Tools didn't help. The emulator starts fine, but deploying GalaxyExplorer fails with:
When I open up this IP address in a browser, everything looks fine:
Any ideas? I'm using a Surface Pro 4 with 8 GB RAM and Windows 10 Pro Build 10586.
Oliver
UX Designer @ Anki
When opening the emulator using the VC++ example template build, can you deploy this ok. Can you open the portal and go to Apps and select and Start the app as in picture.
I deployed the app then right click the Earth and then got this error
This look like a Unity error, bit stuck now
