Acer headphone jack
I cannot seem to figure out how i can get sound trough the headset's headphone jack. When i start the MR portal all the sounds are coming out of my laptop all the time. I cannot see an extra audio device when connecting the headset via usb. Is there something i am missing here?
    MartainMartain
    Answer ✓
    @FranklinChen said:
    There is a headphone jack on the headset, for example, Acer HMD:
    If you plugin in the headphone and wear the headset, you should can hear the sound.
    If not, please ensure the following setting is correct:
    Settings-> Mixed Reality-> Audio and speech
    Sadly that option is already enabled. I think i installed the wrong driver for my HMD. First time i plugged it in after a lot of BSOD, i got it to work by reinstalling the driver that windows suggested. Do you guys see extra sound devices when plugging in the headset? I also still get a lot of BSOD with RtUsbA64.sys (maybe the soundcard of the HMD?)
    MartainMartain
    Answer ✓
    The driver installed is called "Hololens Sensors"
