Intel i7 CPU x980 @3.33 Ghz and Windows Mixed Reality
aqn123
I've been wanting to get Dell Visor recently so I ran a compatibility check on my computer to see. Apparently my cpu (in the title) is not compatible for running Mixed Reality. Why is that? I'm sure it exceeds the minimal requirements.
Hi aqn123,
My name is Etienne and I work with the Mixed Reality support team. I took a look at the specs for your processor and I believe the reason it is throwing an error is because that processor came out in 2010, before AVX support was built into Intel processors (which started in 2011). I am sorry to say that unfortunately you cannot run Mixed Reality without having AVX support on your processor as it is a requirement and there is no way around that requirement. I hope that helps explain things better!
